Results 1 to 4 of 4
    Member franbmx's Avatar
    Nov 2014
    My House
    48
    Vauxhall astra opc
    Question Installation of audible warning and belt sensor
    Do you know how to install the audible seatbelt warning for the driver and passenger?
    I have mounted the two pretensioners that have two cables and the passenger weight sensor and I have activated opcom the two audible warning options and the tachometer icon in the airbag section but it does not work for me.
    Would I miss something else?
    It is an astra h gtc.
      Nov 2014
      My House
      48
      Vauxhall astra opc
      :ni idea: :Llorar: .
      Nov 2014
      My House
      48
      Vauxhall astra opc
      Do the belts have a control unit?
      Or is it the airbags?
      Do you think it could be the problem?
      That my switchboard does not come prepared for that extra?
      Member erik3021's Avatar
      Oct 2024
      Romania
      2
      Opel Astra H 2007
      Hi there! I am also interested in this modification, since my Astra came with the seat belt recognition disabled from the airbag module. But, since the airbag ecu is locked, I cannot modify the configuration in any way. I know for sure that hardware wise I have all the equipment because I wrote on the EEPROM a dump from a car that had this feature activated and it worked, but unfortunately I cannot leave it like that since 2 other settings are not aligned with what my car has.. Does anyone have any idea on how to unlock the airbag ECU? Or which memory adresses from the EEPROM dump contain the configuration? Thanks!
  1. timing belt//water pump replacement
    By Ryan in forum Mechanical
    Last Post: 28th January 2014, 12:42 PM
  2. gates timing belt kit
    By ANT-VXR in forum Mechanical
    Last Post: 30th May 2012, 04:43 PM
  3. 1.9 CDTi Timing Belt Renewal Video
    By Gairo in forum Mechanical
    Last Post: 25th March 2012, 03:14 AM
