Results 1 to 10 of 19
    Member vpug's Avatar
    Dec 2015
    northwest
    33
    twin top
    EEPROM reading astra H Rec
    Hi
    I have just been playing around with a eeprom reading a astra H rec 25040 and tried to
    get a code from Pecky's decode and it cant do it auto, could anyone take a look at the file
    and see if it is incomplete or corrupt.
    Attached Files Attached Files
      1,367
      not a valid file on mine either, will have a manual look at it
      file size reads as correct but it almost looks like its jumped a bit near the top, quick hacked some code together to read it
      Plasma's Decoder Report
      Report Generated on 04/06/2020 17:27:43
      Filename: rec3
      REC Model
      Security Code: 5605
      Vin Number: 0L0AHL6775180195
      Ident: ÿÿ
      Part Number: 16777215
      can you try another read please?
      If its the same then I will amend code to read it properly and ask pecky to see if he will do the same.
      Dec 2015
      northwest
      33
      twin top
      Hi Soulman
      Yes please if you can, I have read it a number of times with the AT 25040 selected and always comes back as the same
      and read another AT 25040 and looks very similar data so is it just my cheap read programmer up.
      Dec 2015
      northwest
      33
      twin top
      Hi Soulman
      Yes when you look at the HEX the vin has the W on one line then the rest on the next.
      I have read the same again eeprom reca and another the of the same type and again W on line above
      eeprom recb. I cant say if reca is the correct code till I put on a car and check with Tech2, recb I have the code for.
      Thanks for lookingrecb.binreca.bin
      1,367
      also the vin is repeated two throughout the eprom whereas the ones already coded into the decoder it appears once..
      i wonder if its a different type of rec (as opposed to a bad read) not come across before
      @pecky
      1,367
      whats the ident of the unit as thats not in the same place and at a glance cant spot it
      Dec 2015
      northwest
      33
      twin top
      Hi
      The two Rec are the same type as used on astra twin top's pic of id below eeprom read on and off the board
      with the same Hex reading.
      cim a I dont know the pass for
      cim b Pass is 5066.
      I would have liked to get the decode from Rec's as I find it the easy way to get readings as I get
      people coming along with no pass code and water damaged rec.
      Thanks for looking
      Dec 2015
      northwest
      33
      twin top
      Hi
      Looking at my Rec's several more IC's on the board than the one in Pecky's pic.
      Thanks Click image for larger version.
      Dec 2015
      northwest
      33
      twin top
      Hi
      Looking at some old posts I have seen below, could this be the same problem ?
      whor22 whor22 is offline
      Member
      whor22's AvatarJoin Date
      Mar 2015
      LV
      5
      Opel
      Country: Latvia
      The code should be 8359. That dump is slightly different to the ones I have and the code is in a different place.
      Could you check the code works and if possible post another dump just to confirm the read was good.
      I can then add this type to my decoder.
      but the dump with pin-code is in only one chip, atmel 25080, i am right?
      Attached Thumbnails Attached Thumbnails
      1,367
      Could well be..
      check yer private messages
  1. EEPROM reading
    By vpug in forum Decoding
    Last Post: 1st June 2020, 10:52 AM
  2. I need help reading eeprom 95640
    By alpine in forum Car Pass
    Last Post: 7th March 2020, 01:28 PM
  3. Reading an eeprom how too????
    By southwalesspares in forum Questions and Info
    Last Post: 12th August 2019, 11:43 AM
  4. Needing eeprom reading
    By gidders2001 in forum Infotainment - ICE - In Car Entertainment
    Last Post: 22nd November 2017, 07:44 PM
https:diagnostics.org.ukshowthread.php9590-EEPROM-reading-astra-H-Rec
https:www.diagnostics.org.ukshowthread.php9590-EEPROM-reading-astra-H-Rec
astra h fuse box eeprom
