Results 1 to 7 of 7
    Member xsatquest's Avatar
    Apr 2012
    Denmark
    44
    Zafira B 1.9CDTI 150HP
    UHP-4 install questions
    So i got the UHP-4 and installed it as per instructions.
    I have enabled the UHP-4 in midspeed canbus in all modules and when i press the top button on the left side it says "No telephone connected" (In german)..I have read that i can have the language changed by Tech-2 service but is it available in all languages or only English, German and other major languages ? (More specifically, is it available in Danish ?)
    Also, i cannot get to the bluetooth menu even though i told both EHU and DIS that the bluetooth portal is present. My understanding is that a variant id is needed to be programmed into the GID (Or EHU ?) ? If this is right i will need tech-2 as the opcom unit i use does not have complete support for my DIS. (What variant for Zafira B)
    On a seperate note....When i took the radio out there were only 3 populated pins in the lower part of the quadlock connector...These 3 pins are left and right aux and gnd ... I have read that the 3½" jack should be in and around the area of the handbrake but have not found it...Does anyone know where the wire is usually tucked away if fitted but not fitted in the other end. ?
    Xsatquest
      7,472
      I can't remember exactly which languages are available, I will make a list next time I connect to mine. It has to be updated via tech2 and SPS to update the firmware.
      Yes you need to program the Variant Configuration of the GID, the mobile phone portal needs to be present, which is the same for astras, vectras, zafiras. The code index is specific to the zafira, but this has nothing to do with bluetooth.
      I believe the other end of the AUX will lead to a black connector under the cup holder to the rear of the handbrake, so you need to remove this.
      Member microdwl's Avatar
      Apr 2012
      the Netherlands
      6
      Zafira B
      Quote Originally Posted by xsatquest View Post
      Xsatquest
      According to the OPEL Mobile Phone Portal manual, the only supported languages for Voice control are :
      German
      (Britisch) English
      French (EU)
      Ialian
      Spanish (EU)
      Dutch
      Apr 2012
      Denmark
      44
      Great
      I am now booked for a tech 2 session next friday.
      What kind of time consumption am i to expect if they should.
      1. Enable Check Control in the GID
      2. Enable Bluetooth menu in the GID
      3. Reprogram the UHP from German to English language
      Just so that i dont end up paying for 4 hours of work if it realistically takes 30 minutes.
      The CC end Bluetooth is enabled in every other module but the display but since i only have the cheap opcom with old software i cannot do the display myself.
      Xsatquest
      7,472
      The time consuming part is the language change. If they use an MDI and tech2win it takes around 20-25 mins, if they use a tech2 hand held, then it takes around 50 mins
      They should be able to do all that in an hours labour charge.
      Apr 2012
      Denmark
      44
      Thanks for the info.
      50 minutes to reflash a box..omg..do they still use 1200baud rs-232 links with tech 2
      Xsatquest
      7,472
      Xsatquest
      That's pretty much exactly what tech2 uses. Take around 10 mins to connect with tech2, prepare for SPS programming and then going through TIS to get to the flashing page, the rest is the painfull download.
      MDI lets you skip the preparing for SPS and runs faster.
  1. Retro fitting CD70 and UHP etc
    By Leegsi in forum Infotainment - ICE - In Car Entertainment
    Last Post: 15th September 2018, 02:45 PM
  2. Bluetooth UHP High Kit Astra J Insignia
    By dreavesy in forum Bluetooth UHP4
    Last Post: 31st August 2018, 12:29 AM
  3. Few questions on eeprom
    By Donwoody1981 in forum Astra
    Last Post: 9th January 2018, 04:58 PM
  4. A few questions for you lot
    By benboym3 in forum Vectra
    Last Post: 29th March 2013, 04:10 PM
uhp4 code index
mobile phone portal vauxhall
how to activate mobile phone portal astra
vauxhall uhp instructions
tech 2 vauxhall bluetooth
vauxhall astra mobile phone portal
opel uhp manual
vauxhall uhp
vauxhall phone portal zafira
zafira mobile phone portal
phone portal setup on a vauxhall astra
bluetooth uhp4
opel mobile phone portal manual
uhp 4 installation
vauxhall uhp update
descargar tutorial uhp4
opel uhp4
zafira b bluetooth uhp4
uhp 4
uhp4 opel
language opel phone portal
quadlock connector navi900
manuale bluetooth uhp opel zafira
opel mobile phone portal update
zafira b ehu code index
