Hi, try in the op-com clone Meriva 2006 section ... but you can not change the index code ... just with tech 2.
GID use pin 12.
Here is code index for tyres:
018
155/80R13
175/65R14
185/55R15
195/45R16
019
165/80R13
165/R13
175/70R14
185/60R15
205/50R16
205/40R17
205/45R17
Thats true for older displays, but newer use 3 and 11 MSCAN... i was asking because there was already wire on 3 going to the old CDR2005, but no wire on 11. Long story short, and to answer myself, it uses both 3 and 11...which means i had to add improvised pin to position 11 in diagnostic connector. My car is 2004 and it did not have it.
Thanks for the code indexes. I will have to visit someone with tech2.
Unfortunately that china clone does not have proper codes for Meriva 2006. There is a mix of different codes from Astra and Zafira. All of them dont work properly.
Yes both 3 and 11.
I looked only your cars my. and as you say older use 3.
What is the my. of that Compo where is the Gid from?
I think 2008. Radio CD70 is 2007 and GID 2004.
Thank you all, it worksToday i've been to the Opel dealer and they enabled it using the code index 018 according to my tire size. They gave me that "are you crazy that cant be done on your car" look, but finally they did it.
So one more time THANK YOU ALL! You are the best.![]()
