Results 1 to 10 of 11
    Member Skyman's Avatar
    Jan 2017
    Scarborough, North Yorkshire
    61
    Astra H 1.7CDTI
    Display options for 2004 Astra !!!
    As my Astra Club CDTI is technically a 'first edition' 2004 am I right in thinking that I'm limited to displays that would work correctly with trip computer functions ?
    Most I've seen are listed to work with 2005 onwards vehicles !!
    I'm asking as I've just got a CD30 MP3 with Aux and it's matching display says 'no function' when I press BC
      What type screen you got?
      No function means its not programmed and its not possible to program bc on screen with 2 buttons (tid screen)
      VIP+ Gav's Avatar
      Nov 2013
      Bristol
      285
      Zafira Tourer & Corsa D
      Or if you have a BID and BC is not activated
      Gav
      Jan 2017
      61
      Astra H 1.7CDTI
      It's a BID that came with the CD30 MP3, so I assume that the BC functions haven't beeem programmed ?
      As it was one of those 'ebay' specials I have no code for either so Tech 2'n isn't going to work
      Its not activated than, as far as i remember code isnt needed for code index programming
      VIP+ Gav's Avatar
      Nov 2013
      Bristol
      285
      If you can get the eeprom bin file off the display. Then we can get the pass code for you
      You will need a eeprom programmer for this to work.
      Gav
      Jan 2017
      61
      Astra H 1.7CDTI
      Cool, I work in the electronics repair industry so I'll sort it ����
      Also, it's from a 2008 Astra so would the BC functions be accurate on my 2004 ?
      Jan 2017
      61
      Astra H 1.7CDTI
      Gav
      It's says on your footer that you've enabled needle sweep ??
      Is this possible on mine ?
      VIP+ Gav's Avatar
      Nov 2013
      Bristol
      285
      Depends if your clocks are compatible.
      Gav
  1. Replies: 2
    Last Post: 16th May 2012, 10:48 PM
