Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Member gc1967's Avatar
    Oct 2016
    Bedford
    97
    Vauxhall combo 1.3 cdti - 2008
    Cruise Control Combo combo 2008 ?
    On my combo 2008 I have checked with opcom and pressed brake and the 2 brake switches say active and press clutch switch that's says active does that mean if I change stalk to cruise control I can have cruise control - obviously there has to be a wire there to BCM fingers crossed if not one would have to be fitted
    If it can be done and is it hard and a lot of hassle
      VIP+ Gav's Avatar
      Nov 2013
      Bristol
      285
      Zafira Tourer & Corsa D
      Yes you can install CC as i have it on my Combo.
      You will need to add a wire from the stalk PIN 4
      to the BCM PIN 2.
      Then activation via variant programming.
      Gav
      Oct 2016
      Bedford
      97
      Quote Originally Posted by Gav View Post
      to the BCM PIN 2.
      Gav
      Is there any chance the wire might be already there and if it's not how hard is it to get it from stalk to BCM and what sort of wire and connectors for the end do you use
      When did you find a cruise control stalk for your combo - Mines a 1.3 cdti - year 2008 - or can you just get a corsa c stalk
      Many thanks for your help
      VIP+ Gav's Avatar
      Nov 2013
      Bristol
      285
      I know for a fact the wire will not be there.
      I have a high spec Combo. AC, electric windows, heated and electric mirrors, cd70 and GID. xenon headlights
      All standard from factory.
      I installed CC to put the spec even higher, just awaiting on some heated leather seats and il be a happy buddy.
      Its one wire that feeds behind the dash to the BCM hole behind the glovebox.
      Yes a Corsa C CC stalk is correct, no other stalk will fit, as they have different patterned plugs.
      Hope this helps
      Gav
      Oct 2016
      Bedford
      97
      Hope this helps
      Gav
      What wire do I need to get and what connectors do I need for each end of the wire ?
      Where's the best place to get a used corsa c cruise control stalk ?
      Is it easy to fit the stalk and the wire from stalk to the BCM ?
      Thanks for your help
      VIP+ Gav's Avatar
      Nov 2013
      Bristol
      285
      I can supply the wire and terminals needed!
      As for the stalk. That's a 3 second job lol.
      You are better of getting one from eBay.
      Oct 2016
      Bedford
      97
      How can I be certain my van can use it using opcom , I know there is a clutch switch above clutch pedal?
      I have looked and looked on eBay for cc stalk but couldn't see anything
      If have read getting the wire from stalk to bcm unit is a nightmare
      Once installed and activated with opcom is there a light on dashboard to show you are using cc
      Sorry for all the questions - total noob
      VIP+ Gav's Avatar
      Nov 2013
      Bristol
      285
      They are rare to find.
      Not really i do have a how2 for installing the loom and to program the cruise control.
      As for the tell tale light sadly not compatible on any clocks
      Oct 2016
      Bedford
      97
      Could you tell me where about a in opcom you look to make sure clutch switch works and 2 brake switches work as I have forgot.
      Looked for a corsa c cc stalk but no luck yet
      VIP+ Gav's Avatar
      Nov 2013
      Bristol
      285
      You need to check the measuring blocks in the engine section and see if the clutch switch activates when pressed.
      80% sure the clutch and brake switch are present, due to being a diesel.
      As for activation iirc there are 3 places to activate it
  1. combo fails
    By welderman in forum Other cars
    Last Post: 28th September 2018, 08:36 PM
  2. Cruise Control on combo van
    By gc1967 in forum Cruise Control
    Last Post: 18th October 2016, 07:44 AM
  3. New combo
    By Rob in forum Other cars
    Last Post: 8th April 2013, 07:37 PM
jow to programme cruise control combo c
https:www.diagnostics.org.ukshowthread.php6273-Cruise-Control-Combo-combo-2008
