Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 37
  1. #11
    Member Daz21's Avatar
    Mar 2016
    Wiltshire
    16
    Astra j
    Can you pm me all info plz
    • #12
      Mar 2016
      Wiltshire
      16
      Astra j
      Can you pm me all info plz as not sure what you mean mate.
    • #13
      Mar 2016
      Wiltshire
      16
      Astra j
      You still there mate ?
    • #14
      1,367
      he means u need to strip it all down, get to the eprom in the actual instrument cluster itself, use an eprom programmer to read the contents of the file and then upload it to us for check..
    • #15
      That is eeprom it needs to be de- soldered from instrument cluster
      Than it needs to be read with eeprom programmer and files saved than post them files here
      If you cant get these files we cant help you.
      Teamviewer has not implented yet function remote soldering/desoldering function
    • #16
      Mar 2016
      Wiltshire
      16
      Astra j
      Hi so if I read the eeprom not a problem then replace the vin with my vin and my security code ( replace all on the eeprom ) then writ it back to the chip - so I need to program it to my car again or is that it ?? Please can you get back to me thanks. Pm me if needed
    • #17
      Replace vin and security code and make sure mileage is correct in 3 places, you dont need to program it again.
    • #18
      Mar 2016
      Wiltshire
      16
      Astra j
      So what's done is correct the only this I see is that the vin is written 100s times same as security code as it goes up then down again but could not see a reference to mileage in the eeprom Pm me
    • #19
      Vin is only in one place and security code in one place too
      If you got it in more than one place you are doing something wrong or your tool what you used for mileage corretion corrupted you eeprom data. Mileage is encrypted it wont be plain text
    • #20
      Mar 2016
      Wiltshire
      16
      Astra j
      Pm me please I can explain more
  1. corsa d non start ff in mileage display
    By tremo1984 in forum Corsa
    Last Post: 15th March 2016, 03:36 PM
  2. mileage guide for parts (astra 1.9 150)
    By Ryan in forum Mechanical
    Last Post: 28th January 2013, 10:14 PM
https:diagnostics.org.ukshowthread.php6214-astra-j-mileage-display
https:www.diagnostics.org.ukshowthread.php6214-astra-j-mileage-display
astra j mileage correctionvauxhall astra j mileage not showinghttps:www.diagnostics.org.ukshowthread.php6214-astra-j-mileage-displaypage2vauxhall astra k cluster eepromastra j odometer op-comastra j 2015 odometar write2012 astra j dashboard display outastra j mileagr correctionastra j mileage location
