Results 1 to 3 of 3
    Member Daver944's Avatar
    Aug 2016
    Southampton
    1
    Zafira B 2007 1.6 life
    Zafira B Fault code ECN160638
    Hi from newbie, I have 2007 Zafira 16 Life, approx. 80000 miles.
    For the past 12 months the engine management light (orange) has been on and off intermittently; car has run fine during this period. (Fault code 0171: i've cleaned the inlet manifold and checked the operation of the EGR valve)
    Occasionally it has refused to start (maybe twice in the past year), but after being left for a few days it starts and runs fine.
    Last week we were on holiday in UK and used the car to drive from Southampton to Essex and back which it did with no problems.
    The day after we returned we went to start the car; it refused to start and seemed to spit back in the air cleaner.
    Later that day I tried again; the engine would start and race to ~5000rpm for about 2 seconds then cut-out. (without touching the throttle pedal). it has done this repeatedly since.
    Occasionally it will run at approx. 1000rpm making 'strange' noises (not very technical description) and again after about 2 seconds then cuts out.
    The faults (using the pedal trick) were:
    17152 Which I assume is the EGR valve or the ports in the cylinder head
    P0201
    P0202
    P0203
    P0204
    160638
    After again cleaning the EGR valve (didn't seem to need cleaning) I checked the fault codes and now have 160638.
    The battery voltage is good (12,5 volts), I have taken the electrical panel (with fuses and relay) off and checked for corrosion: I couldn't see any, but sprayed some electrical cleaner anyway for good measure.
    I have taken the connectors off the ECU: they are clean with no signs of corrosion.
    from various forums it looks like a new ECU is required: any comments from the experts out there?
      Member liviu2004's Avatar
      Feb 2014
      Netherlands
      150
      Opel
      P0606 Replace Electronic Control Unit (ECU)
      P0606 Capacitor Voltage 1 Low Voltage
      P0606 Capacitor Voltage 1 High Voltage
      P0606 Electronic Control Unit (ECU) - Malfunction
      The control unit recognises an internal control unit malfunction or is influenced by interference voltage from the following component: A40 Ignition Coil - Direct Ignition
      P0606 System Voltage High Input >17V
      P0606 Control Unit Re-Initialisation
      Member nikh667's Avatar
      Nov 2016
      Bodmin
      12
      Astra 1.9CDTi
      Did you find a resolution to this?
      P1606 (Symptom Byte 38) is for "Engine Torque Not Plausible" - this will tie in with the P0171 fuel system issue and also the symptoms you're getting with the running problems. It doesn't sound ECM related to me, moreso something along the lines of an intake air leak affecting the reading to the MAP sensor, which will throw the fuelling off right across the whole rev range.
  1. Zafira Fault Code with Pedal Test ECN 111606
    By anthmills2000 in forum Zafira
    Last Post: 19th November 2014, 11:06 PM
  2. fault code RXE
    By mookev in forum Astra
    Last Post: 11th August 2013, 10:14 PM
  3. Zafira B fault code p2279
    By Griff in forum Zafira
    Last Post: 3rd May 2013, 12:17 PM
https:diagnostics.org.ukshowthread.php6152-Zafira-B-Fault-code-ECN160638
https:www.diagnostics.org.ukshowthread.php6152-Zafira-B-Fault-code-ECN160638
engine torque not plausible
https:diagnostics.org.ukshowthread.php6152-Zafira-B-Fault-code-ECN160638p=49053how can i test the egr valve on a 08 1.6 petrol zafira b2007 vauxhall zafira p1606 engine torque implausiblefault code 160638zafira pedal test 017107 zafira 1.6 error codes p0171. 0201 0202 .0203 .0204 .zafira fault codes 160638ecn 160638
