Results 1 to 4 of 4
    VIP+ southwalesspares's Avatar
    May 2016
    wales
    11
    none
    Car pass other information and codes question
    Another general question now I've managed to do 2 stereo's and a GID I'm getting the hang of it.
    Question is, I read a GID and a CD30 MP3 off of a Corsa D, and got the same security code, including the correct vin number from the GID, The code I'm getting say's security code, but is the key number and radio code different? Just I see from reference car pass photo's that the key and radio code is never the same as the security code, are these two codes needed and for what and can you retrieve them if they are needed? I was assuming that you could retrieve the code for the stereo at least, just checking what you can and can't do, and what is and isn't needed.
    Also some car passes mention an immobiliser code? is this needed and if so for what?
    Thanks for any input
      7,471
      Using the Astra Range as an example, but applies to other cars in the same age bracket.
      Astra G - Separate radio code and immobiliser code (Security Code)
      Astra H - One single code for security, immobiliser, radio, basically everything in the car
      Astra J - One single security code for BCM, IPC and probably other things, but modules do a VIN check for security check not security code.
      Astra K - No car pass at all is provided, has to be done online and it gets the code off the server and auto inputs it.
      May 2016
      wales
      11
      none
      Thanks for the Reply Pecky, on that score what would be the score with the following vehicles, been the ones I mainly deal in.
      Corsa C an D variant.
      Vectra C Assuming same as Astra H
      Zafira B Asumming same as Astra H
      Meriva A and B Assuming same as age of corsa
      And finally the Insignia, I'm assuming this may be the same as the Astra J but not sure if you've done much on them yet.
      Appreciate the info.
      7,471
      Corsa C is the same as Astra G
      Corsa D is same as Astra H
      Vectra C depends on age i.e full or half can
      Meriva, I think you are correct
      Insignia, is one code for whole car, but uses VIN checks for security.
  1. Car pass
    By killers2 in forum Vectra
    Last Post: 2nd October 2019, 03:19 PM
  2. Zafira b car pass help
    By Gamesaddict2010 in forum Car Pass
    Last Post: 7th June 2018, 06:34 PM
  3. Help with car pass code
    By killer32 in forum Car Pass
    Last Post: 24th March 2018, 06:39 PM
do i get radio and immobiliser codes with car pass
gid decode using carpass
car pass security code vin decoder
car pass opel astra h security code gleich Radio code
https:www.diagnostics.org.ukshowthread.php6041-Car-pass-other-information-and-codes-question
https:diagnostics.org.ukshowthread.php6041-Car-pass-other-information-and-codes-question
