Results 1 to 6 of 6
    Member paulwhite1987's Avatar
    Dec 2013
    wombourne
    42
    zafira b
    Possible Broken CV joint!
    As title says I think the inner cv joint has failed today. Been fine up to today and only recent work that's been done was the track rods and track rod ends last month. Symptom are an occasional clunk more common at low speeds when the power hits the wheels. Don't think it's the outer joints as it doesn't do it when the wheel is turned, it just seems more intermittent.
    Is is there any way of getting a definitive answer before I get them changed. Also does anyone know what the cost is and where I could get the work done
  1. [WANTED] Wanted astra h/zafira b cid broken cid display.
    By lampinen in forum Wanted
    Last Post: 18th October 2016, 10:15 PM
  2. Corsa D GID - Broken ?
    By ulb in forum Board Computer
    Last Post: 29th August 2016, 07:11 PM
  3. How to: Fix broken headlight brackets
    By RobertWeaver in forum How to
    Last Post: 16th February 2014, 08:45 PM
  4. Broken wire
    By EdopcBurg in forum Astra
    Last Post: 8th November 2013, 03:19 PM
