My mates van had 60/40 but it was factory fitted and on the logbook.. Welcome
btw mate
Hi guys I'm looking to get rear seats fitted into the back of my 53 astravan.just woundering how much it's cost and how hard it was to do, I need the 60/40 seats really not the bench, any info would be great cheers
btw mate
Cheers mate, I have seen a few after market conversions in google images and one was posted on here by Luke, I did get a quote from few company's but cost way to much.
firstly welcome to the club ,I think it looks quite straight forward m8 you just need to remove the false floor first that look like the hardest bit
also moved thread to correct section![]()
if you put ur mind to it mate ul get it done if you need any help ukno where iam
I'm sure theres spot welds behind the seats that need to be drilled out and then its a case of removing the floor, apparently the bolt holes for the factory esate rear seats are already there as well as the belt anchors
Ahh I been looking for this thread lol .
Cool so there's a floor to sit the seats in under the flat floor?
And will I have to get estate seats?
The van floor is laid over the top of an estate platform Lee, the floor is just covering the standard seat mounts so as said, you can remove the floor panel and then the bench from an estate will bolt straight in...
The only seat that will fit properly is the estate bench...
