Anyone ???
Anyone know if Vauxhall Zafira Design Nav Touch & Connect 13 plate has audio out and if so, where could I get the removal tool.
kindest Regards
Daniel
Anyone ???
What radio does it have? CD 30 or CD70 etc. Easiest way to tell is if you remove radio and there will be a socket for audio input on the back. Factory fitted audio input is fitted below the lighter socket
Sorry mate, I'm after audio out and it's the sat nav version touch and connect is written on it but I can't get the stereo out
Regards
Oh I doubt the oem head units do an audio output. If it's for an amp there is a way around it by using a loom to convert the speaker outputs
I'm a slight noob when it comes to that and yeh it will be for an amp. Any links/ideas?
Regards
Something similar to this
http://www.caraudiodirect.co.uk/cels...converter.html
They also sell something similar at halfords or on eBay
