Results 1 to 10 of 10
    Member kevinyi's Avatar
    Sep 2014
    Seoul korea
    40
    antara
    UHP4 installation question on antara.
    Dear all.
    I was trying to install uhp4 on antara 09.
    seller send it to me productor as below.
    But. Antara didn't have CIM module i guess.
    Any idea Sir.
    Have a good weekend.
    Kevin.
    Programming - detail
    Security code card company to the Opel dealer
    With the Tech 2 must be at least the year 2008 or younger
    be entered
    Tech 2 at least version 122.00 or later, otherwise no connection to
    UHP
    1. 1st The first thing should be selected and there with the Tech 2 with the CIM
    Programming → MID-speed configuration on the UHP4 of missing
    be placed there.
    2. 2nd The display is selected. Then programming → Variant Configuration
    -> Change of universal hands-free does not exist at present.
    3. 3rd If the CIM is done the radio must be selected. → under Programming
    Variant Configuration of the Universal Handsfree is not available on
    any change.
    If no automatic climate control (ECC) is installed, please proceed to Step 5.
    4. 4th If it is installed in the car an automatic climate control, then the control unit of ECC
    be selected. Programming → MID-speed configuration available to UHP
    . set
    5. 5th Now you have the UHP control unit 4 to be selected. Under the program must now
    Control unit can be programmed.
    Tech 2 leads through programming.
    The MID-speed configuration, radio, display, UHP and ECC (if available)
    be changed from absent to present.
    It is called the variant configuration where Bluetooth is set to present
    be. Input language should be set to German.
    Later in the Tech 2 will index the code programming. I recommend the
    Index of Antaras code for each vehicle (see list)
    As a final step, the Tech 2 is the UHP with the radio control unit and the display
    . marry
    The Tech 2 automatically selects the programming sequence to the radio and automatically
    goes into
    MID-speed configuration of the radio. There must not exist from the UHP to
    be placed there.
    Then the Tech2 2x in a row will then know the security code of the vehicle.
    Now, the speakerphone is full functional.
    Click image for larger version. Name: 12345.jpg Views: 0 Size: 1.7 KB ID: 1131
      7,472
      CIM module programming is only really important if you have a CDC40 radio as the steering controls for the bluetooth, change the CD when bluetooth is not fitted. So the programming just changes that.
      Sep 2014
      Seoul korea
      40
      antara
      Dear Sir.
      I have a radio version CD30 MP3 2009 year.
      It is not possible to do it?
      Thank you verrry much Sir.
      Kevin.
      also I am looking for uhp4 owner manul.
      Cd30mp3 + uhp fully possible but if you have gid or cid screen otherwise you must change screen and you will need patch lead or buy a kit from pecky
      Sep 2014
      Seoul korea
      40
      antara
      Master Pecky and Domtorredo Sir.
      Hardware is CD30 mp3+GID trip .
      I am wondering where is the CIM modul located at on antara?
      Thank you for million.
      Have a good day Sir.
      Kevin.
      Member sarah1331's Avatar
      Dec 2013
      Rotherham
      442
      Vectra c
      are you sure you gave gid? do you have climate control?
      cd30 standard screen is bid
      Sep 2014
      Seoul korea
      40
      antara
      Yes,I sure Sir.
      http://me2.do/G0at0zcK
      http://me2.do/5luWHIQb
      Also I have a ECC.
      I 'v checked the ECC program mode. But it's not exist there.
      I see the ECC module on module present check mode.
      Thank you sir.
      Kevin
      Cim on vauxhall was and will be on steering column right after steering wheel but i can't understand why you are looking for cim if you dont need to change anything in there?
      Sep 2014
      Seoul korea
      40
      antara
      Master domtorredo Sir.
      I was trying to follow procedure instrction step for make it working.
      I though i was miss understood.
      But it is little diffrent on Antara setting I guess.
      One thing I found
      CIM = under GID program veriant
      I have to changeed the steering wheel control option to present on GID.
      Also mobile Phone portal to preset,too.
      http://me2.do/GAOXch7X
      It is working perfectly after changes it now.
      Tnak you so much.
      I would a appreciate your help.
      Kevin.
      Finlly,
      Always welcome
  1. UHP4 bluetooth installation procedure.^^
    By kevinyi in forum Antara
    Last Post: 26th May 2022, 06:02 PM
  2. Antara Touch&connect USB wiring question
    Last Post: 20th October 2018, 01:54 PM
  3. Antara touch connect radio wiring question
    Last Post: 14th October 2018, 11:08 AM
  4. UHP4 question
    By manevni0 in forum Infotainment - ICE - In Car Entertainment
    Last Post: 3rd July 2018, 01:33 AM
  5. UHP4 installation question on antara.
    By kevinyi in forum Bluetooth UHP4
    Last Post: 26th September 2014, 07:24 AM
programming uhp4
