Results 1 to 3 of 3
    1 - Body Exterior Fittings
    MUDFLAPS - EXCEPT OPC,VXR
    1X 32026218 17 18 332 KIT, FRONT MUDFLAPS 1
    2X 32026219 17 18 333 KIT, REAR MUDFLAPS 1
    ROOF CARRIER SYSTEM - BASE (EXCEPT VAUXHALL)
    1X 32026167 67 32 550 KIT, BASE CARRIER, 100 KG LOAD CAPACITY (ALUMINIUM) HATCH, SALOON 68, 69 1
    1X 32026169 67 32 548 KIT, BASE CARRIER, 100 KG LOAD CAPACITY (ALUMINIUM) ESTATE 35 1
    ROOF CARRIER SYSTEM - BASE (FOR VAUXHALL)
    1X 32026168 KIT, BASE CARRIER, 100 KG LOAD CAPACITY (ALUMINIUM) HATCH, SALOON 68, 69 1
    1X 32026170 KIT, BASE CARRIER, 100 KG LOAD CAPACITY (ALUMINIUM) ESTATE 35 1
    ROOF CARRIER SYSTEM - ROOF CARRIER
    2 9162904 67 32 474 CARRIER, CYCLE (SIDE LIFT VERSION) (FOR 1 BICYCLE) (FOR EUROPE) (FOR USE IN CONJUNCTION WITH 9162906) 1
    3X (9162907) (67 32 489) SET, MOUNTING, SINGLE CYCLE (SIDE LIFT VERSION) (FOR 'C' PROFILE BASE CARRIER) (USE IN CONJUNCTION WITH 9162904) (FOR EUROPE) (NLS.- NO REPLACEMENT PART) 1
    4 (32000586) (17 32 538) CARRIER, SKI/SNOWBOARD, LOCKABLE, HORIZONTAL (FOR MAXIMUM OF 6 PAIRS SKIS AND 4 SNOWBOARDS) (FOR EUROPE) (NLS.- NO REPLACEMENT PART) 1
    5 (12799191) (67 32 545) ROOF STORAGE BOX, 30KG LOAD CAPACITY, 480 LITRE, 2200 X 900 X 300MM (REAR SINGLE SIDE OPENING) (FOR EUROPE) (USE IN CONJUNCTION WITH BASE CARRIER SYSTEMS) (NLS.- NO REPLACEMENT PART) 1
    6 32025666 67 32 544 ROOF STORAGE BOX, SPORT, 30KG LOAD CAPACITY, 460 LITRE, 2250 x 900 x 290 MM (REAR SIDE OPENING) (FOR EUROPE) (USE IN CONJUNCTION WITH BASE CARRIER SYSTEMS) 1
    7 (93199515) (67 32 293) ROOF STORAGE BOX, BLACK, 50KG LOAD CAPACITY, 450 LITRE, 1750 X 820 X 450 MM (SINGLE SIDE OPENING, RH SIDE) (FOR EUROPE) (USE IN CONJUNCTION WITH BASE CARRIER SYSTEMS) (NLS.- NO REPLACEMENT PART) 1
    7 (93199516) (17 32 125) ROOF STORAGE BOX, BLACK, 50KG LOAD CAPACITY, 450 LITRE, 1750 X 820 X 450 MM (SINGLE SIDE OPENING, LH SIDE) (FOR EUROPE) (USE IN CONJUNCTION WITH BASE CARRIER SYSTEMS) (NLS.- NO REPLACEMENT PART) 1
    7 (93199517) (67 32 294) ROOF STORAGE BOX, BLACK, 50KG LOAD CAPACITY, 450 LITRE, 2320 x 700 x 390 MM (SINGLE SIDE OPENING, RH SIDE) (FOR EUROPE) (USE IN CONJUNCTION WITH BASE CARRIER SYSTEMS) (NLS.- NO REPLACEMENT PART) 1
    7 (93199518) (17 32 124) ROOF STORAGE BOX, BLACK, 50KG LOAD CAPACITY, 450 LITRE, 2320 x 700 x 390 MM (SINGLE SIDE OPENING, LH SIDE) (FOR EUROPE) (USE IN CONJUNCTION WITH BASE CARRIER SYSTEMS) (NLS.- NO REPLACEMENT PART) 1
    8 (93199519) (67 32 295) ROOF STORAGE BOX, BLACK, 75KG LOAD CAPACITY, 480 LITRE, 1960 x 780 x 440 MM (DUAL SIDE OPENING) (FOR EUROPE) (USE IN CONJUNCTION WITH BASE CARRIER SYSTEMS) (NLS.- NO REPLACEMENT PART) 1
    9 93199506 67 32 292 ROOF STORAGE BOX, GREY, 50KG LOAD CAPACITY, 320 LITRE, 1330 X 860 X 370 MM (DUAL SIDE OPENING) (FOR EUROPE) (USE IN CONJUNCTION WITH BASE CARRIER SYSTEMS) 1
    REAR MOUNTED CARRIER SYSTEM
    10 93199827 17 32 665 CARRIER, CYCLE, LOCKABLE (FOR 2 BICYCLES) (MOUNTED ON TRAILER COUPLING) (36KG LOAD CAPACITY) 1
    11X 93199753 17 32 663 KIT, CYCLE CARRIER, ADDITIONAL (FOR 1 BICYCLE) (MOUNTED ON TRAILER COUPLING) (18KG LOAD CAPACITY) (USE IN CONJUNCTION WITH 93199827) 1
      FRONT BUMPER
      1 93199810 17 19 288 EXTENSION, FRONT BUMPER 1
      SILL COVER
      2X 93199812 17 19 286 MOULDING, SILL PANEL, RH, PRIMER (KIT) 1
      2X 93199813 17 19 287 MOULDING, SILL PANEL, PRIMER, LH (KIT) 1
      3 90087290 11 04 880 -RIVET, EXPANDING, SILL PANEL MOULDING 10
      4 9202829 13 41 719 -SCREW, TORX, M4 X 35, SILL PANEL MOULDING 10
      REAR SPOILER
      5 93199814 17 19 280 SPOILER, REAR HATCH 68
      5 93199822 17 19 281 SPOILER, REAR SALOON 69
      REAR BUMPER
      6 93199811 17 19 283 EXTENSION, REAR BUMPER PANEL MOULDING HATCH, SALOON 68, 69 1
      7X 93199815 17 19 282 EXTENSION, REAR BUMPER PANEL MOULDING ESTATE 35 1
      BODY STYLING KIT - OPC,VXR,LINE PACK 1
      8X 13344010 17 05 107 KIT, STYLING HATCH 68 1
      8X 13344011 17 05 108 KIT, STYLING SALOON 69 1
      9X 13344012 17 05 109 KIT, STYLING ESTATE 35 1
      PROTECTIVE STRIPS
      10X 13366676 17 19 126 KIT, FOIL, PROTECTIVE, BODY, PAINT HATCH, SALOON 68, 69 (C) C1000001- 1
      10X 13366677 17 19 135 KIT, FOIL, PROTECTIVE, BODY, PAINT ESTATE 35 (C) C1000001- 1
      10X 13366678 17 19 136 KIT, FOIL, PROTECTIVE, DOORS, PAINT (C) C1000001- 1
      10X 13366679 17 19 137 KIT, FOIL, PROTECTIVE, FRONT BUMPER, PAINT (C) C1000001- 1
      TRAILER COUPLING
      1 32026173 17 36 372 COUPLING, ASSY., TRAILER, FIXED BALL TYPE (TRAILER LOAD 1800KG, SUPPORTING LOAD 85KG) HATCH, SALOON 68, 69, EXCEPT OPC, VXR 1
      2 32026174 17 36 373 COUPLING, ASSY., TRAILER, REMOVABLE BALL TYPE (TRAILER LOAD 2100KG, SUPPORTING LOAD 85KG) HATCH, SALOON 68, 69 1
      3 32026172 17 36 371 COUPLING, ASSY., TRAILER, FIXED BALL TYPE (TRAILER LOAD 2100KG, SUPPORTING LOAD 85KG) ESTATE 35 1
      4 32026175 17 36 374 COUPLING, ASSY., TRAILER, REMOVABLE BALL TYPE (TRAILER LOAD 2100KG, SUPPORTING LOAD 85KG) ESTATE 35 1
      5 13324883 17 36 323 DRAWBAR, REMOVABLE, TRAILER COUPLING 1
      6 13107366 67 36 270 PLUG, REMOVABLE DRAWBAR APERTURE 1
      TOWING ROPE
      7 93199453 17 38 628 ROPE, TOWING (FOR VEHICLES UP TO 3000KG TOTAL WEIGHT) 1
      TOWING BAR
      8 90019071 17 90 522 BAR, TOWING (FOR VEHICLES UP TO 2500KG TOTAL WEIGHT) (PRODUCTION NO. 91143726) 1
  1. 2 - Body Interior Fittings
    By pecky in forum Q - ACCESSORIES
    Last Post: 29th December 2013, 10:11 AM
  2. 7 - Exterior Lighting
    By pecky in forum P - ELECTRICAL
    Last Post: 28th December 2013, 08:10 PM
  3. Exterior Lighting
    Last Post: 4th December 2011, 06:49 PM
  4. Body Exterior Fittings
    Last Post: 4th December 2011, 03:09 PM
  5. Body Interior Fittings
    Last Post: 4th December 2011, 01:09 PM
catalog number 67 32 548 # 32026169
