Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
    1 - Engine and Cooling
    POWERTRAIN SENSORS AND ENGINE CONTROL MODULE - A14NET[LUJ] PETROL ENGINE (OIL PRESSURE SWITCH)
    1 93190643 12 38 696 SWITCH, M10 X 1, OIL PRESSURE (PRODUCTION NO. 55571864) 1
    2 55576784 12 40 390 INSULATOR, OIL PRESSURE SWITCH 1
    POWERTRAIN SENSORS AND ENGINE CONTROL MODULE - A14NET[LUJ] PETROL ENGINE (COOLANT TEMPERATURE SENSOR)
    3 55353807 63 38 045 SENSOR, TEMPERATURE, ENGINE COOLANT, THERMOSTAT HOUSING 1
    4 55555982 63 38 481 RETAINER, SENSOR, WATER TEMPERATURE 1
    POWERTRAIN SENSORS AND ENGINE CONTROL MODULE - A14NET[LUJ] PETROL ENGINE (CAMSHAFT SPEED SENSOR)
    5 55566932 12 37 183 SENSOR, CAMSHAFT REVOLUTIONS 2
    6 11097981 20 05 624 SCREW, TORX, M6 X 16, CAMSHAFT SPEED SENSOR TO TIMING HOUSING 1
    POWERTRAIN SENSORS AND ENGINE CONTROL MODULE - A14NET[LUJ] PETROL ENGINE (CRANKSHAFT SPEED SENSOR)
    7 55571994 12 38 268 SENSOR, CRANKSHAFT REVOLUTIONS (DUAL FUEL - LPG) 1
    7 55571977 12 47 086 SENSOR, CRANKSHAFT REVOLUTIONS (EXCEPT DUAL FUEL - LPG) 1
    8 11097981 20 05 624 SCREW, TORX, M6 X 16, CRANKSHAFT SPEED SENSOR TO CYLINDER BLOCK 1
    POWERTRAIN SENSORS AND ENGINE CONTROL MODULE - A14NET[LUJ] PETROL ENGINE (KNOCK LIMIT SENSOR)
    9 55563372 12 36 006 SENSOR, KNOCKING LIMIT, CYLINDER BLOCK 1
    10 11093612 20 05 973 SCREW, TORX, M8 X 25, KNOCK LIMIT SENSOR TO CYLINDER BLOCK 1
    POWERTRAIN SENSORS AND ENGINE CONTROL MODULE - A14NET[LUJ] PETROL ENGINE (INDUCTION MANIFOLD VACUUM SENSOR)
    11 55568175 12 35 029 SENSOR, VACUUM, INLET MANIFOLD 1
    12 55563672 12 38 661 SCREW, M4 X 20, VACUUM SENSOR TO INDUCTION MANIFOLD 1
    POWERTRAIN SENSORS AND ENGINE CONTROL MODULE - A14NET[LUJ] PETROL ENGINE (CATALYTIC CONVERTER SENSOR)
    13 55563348 8 55 235 SENSOR, OXYGEN, HEATED, CATALYTIC CONVERTER (POSITION 1) (IDENT DJ) 1
    14 55562206 8 55 252 SENSOR, OXYGEN, CATALYTIC CONVERTER (POSITION 2) 1
    POWERTRAIN SENSORS AND ENGINE CONTROL MODULE - A14NET[LUJ] PETROL ENGINE (ENGINE CONTROL UNIT)
    15 12643636 12 47 282 CONTROL UNIT, ENGINE, UNPROGRAMMED (IDENT AAL2) 1
    16 13243603 12 37 099 BRACKET, ENGINE CONTROL UNIT 1
    17 11514516 6 07 724 NUT, HEX., M6, BRACKET FIXING 4
  2. #1
    IGNITION MODULE - A14NET[LUJ] PETROL ENGINE
    1 55579072 12 08 096 MODULE, IGNITION 1
    2 11098802 20 48 757 SCREW, TORX, M6 X 60, IGNITION MODULE TO CYLINDER HEAD 2
    SPARK PLUG - A14NET[LUJ] PETROL ENGINE
    3 55576026 12 14 066 PLUG, ASSY., SPARK (IFR7X-7G) 4
    STARTER - A14NET[LUJ] PETROL ENGINE
    4 55578921 12 02 217 STARTER, ASSY. (DUAL FUEL - LPG) 1
    4 55578921 12 02 217 STARTER, ASSY. (EXCEPT STOP/START ENGINE SYSTEM) 1
    4 55572440 12 02 227 STARTER, ASSY. (FOR STOP/START ENGINE SYSTEM) 1
    5 11048336 20 18 000 SCREW, HEX.HD., M8 X 48, STARTER TO CYLINDER BLOCK 1
    6 55561930 20 00 541 SCREW, M8 X 48, STARTER TO CYLINDER BLOCK 1
    ALTERNATOR - A14NET[LUJ] PETROL ENGINE
    7 13581885 12 02 244 ALTERNATOR, ASSY., 100 AMP 1
    7 13581892 12 02 296 ALTERNATOR, ASSY., 120 AMP 1
    8 13577154 12 02 215 ALTERNATOR, ASSY., 140 AMP (IDENT AA7) (EXCEPT STOP/START ENGINE SYSTEM) 1
    9 13258483 12 04 177 -PULLEY, ALTERNATOR (FOR USE WITH 140 AMP. ALTERNATOR) 1
    10 13581893 12 02 243 ALTERNATOR, ASSY., 140 AMP (IDENT ADS) (FOR STOP/START ENGINE SYSTEM) 1
    11 55580127 12 04 293 -PULLEY, ALTERNATOR (FOR USE WITH 120AMP. ALTERNATOR) (FOR USE WITH 140 AMP. ALTERNATOR) 1
    12 11588755 20 05 209 SCREW, HEX.HD., M10 X 115, ALTERNATOR TO CYLINDER BLOCK 2
    DRIVE BELT - A14NET[LUJ] PETROL ENGINE
    13 55562418 13 40 016 BELT, DRIVE, ALTERNATOR (EXCEPT AIR CONDITIONING) (IDENT KJ) (PRODUCTION NO. 55562419) 1
    14 55578811 13 40 018 BELT, DRIVE, ALTERNATOR (IDENT LH) (FOR AIR CONDITIONING) 1
    15 55565236 13 40 267 ROLLER, TENSION 1
    16 11097431 20 48 992 SCREW, TORX, M8 X 30, TENSIONER TO BLOCK 1
  3. #1
    IGNITION MODULE - A16XER[LDE],A18XER[2H0] PETROL ENGINES
    1 55561655 12 08 086 MODULE, IGNITION COIL (PRODUCTION NO. 96476983) 1
    2 11102371 20 24 064 SCREW, TORX, M6 X 75, IGNITION MODULE TO CYLINDER HEAD 2
    SPARK PLUG - A16XER[LDE],A18XER[2H0] PETROL ENGINES
    3 93176801 12 14 031 PLUG, ASSY., SPARK (FQR8 LEU2) (PRODUCTION NO. 55351865) 4
    STARTER - A16XER[LDE],A18XER[2H0] PETROL ENGINES
    4 (55556092) (62 02 084) STARTER, ASSY. (EXCHANGE PART 93169022 OPEL) (NLS.- USE 55576980) 1
    - 93192288 12 02 254 -SOLENOID SWITCH, STARTER 1
    - (93192286) (12 03 680) -PINION, STARTER (NLS.- NO REPLACEMENT PART) 1
    - 93192289 12 03 682 -SET, CARBON BRUSHES, WITH HOLDER 1
    - 93192287 12 03 681 -TRANSMISSION, PLANETARY, STARTER 1
    5 55561930 20 00 541 SCREW, M8 X 48, STARTER TO CYLINDER BLOCK 1
    6 11048336 20 18 000 SCREW, M8 X 25, STARTER TO CYLINDER BLOCK 1
    ALTERNATOR - A16XER[LDE],A18XER[2H0] PETROL ENGINES
    7 (13500577) (12 04 654) ALTERNATOR, ASSY., 100 AMP (IDENT BF) (NLS.- USE 13579666) 1 @
    8 13500586 12 04 622 ALTERNATOR, ASSY., 120 AMP (IDENT BX) 1
    8 13500329 12 04 621 ALTERNATOR, ASSY., 140 AMP (IDENT BY) 1
    9 13258483 12 04 177 -PULLEY, ALTERNATOR (FOR USE WITH 120/140 AMP. ALTERNATOR) 1
    10 11102841 20 48 205 SCREW, ALTERNATOR TO BRACKET, M10 X 95 2
    DRIVE BELT - A16XER[LDE],A18XER[2H0] PETROL ENGINES
    11 55565301 13 40 279 BELT, DRIVE (EXCEPT AIR CONDITIONING) 1
    12 55563925 13 40 275 BELT, DRIVE (IDENT JS) (FOR AIR CONDITIONING) 1
    13 55563512 13 40 268 ROLLER, TENSION (IDENT BA) 1
  4. #1
    IGNITION MODULE - A16LET[LLU] PETROL ENGINE
    1 10458316 12 08 021 MODULE, IGNITION COIL (PRODUCTION NO. 1104082) (C) -B1999999 1
    1 55561655 12 08 086 MODULE, IGNITION COIL (PRODUCTION NO. 96476983) (C) C1000001- 1
    SPARK PLUG - A16LET[LLU] PETROL ENGINE
    3 55564763 12 14 528 PLUG, ASSY., SPARK (ZFR6BP-G) 4
    STARTER - A16LET[LLU] PETROL ENGINE
    ALTERNATOR - A16LET[LLU] PETROL ENGINE
    DRIVE BELT - A16LET[LLU] PETROL ENGINE
  5. #1
    IGNITION MODULE - A20NHT[LDK],A20NFT[LHU] PETROL ENGINES
    1 12638824 48 02 236 MODULE, IGNITION COIL (C) C1000001- 1
    2 11589083 48 05 093 SCREW, IGNITION COIL TO CYLINDER HEAD 2
    3 11518792 63 38 053 SLEEVE A20NFT[LHU] 1
    SPARK PLUG - A20NHT[LDK],A20NFT[LHU] PETROL ENGINES
    4 12620540 48 11 581 PLUG, ASSY., SPARK 4
    STARTER - A20NHT[LDK],A20NFT[LHU] PETROL ENGINES
    5 12609317 12 02 186 STARTER, ASSY. (C) -A1999999 1
    5 12637159 12 02 222 STARTER, ASSY. (EXCEPT STOP/START ENGINE SYSTEM) (C) B1000001- 1
    5 12644406 12 02 231 STARTER, ASSY. (FOR STOP/START ENGINE SYSTEM) (C) C1000001- 1
    6 11588741 20 00 373 SCREW, 10X 45, STARTER TO CYLINDER BLOCK 1
    7 13277142 6 62 925 STUD, STARTER MOTOR TO CYLINDER BLOCK 1
    ALTERNATOR - A20NHT[LDK],A20NFT[LHU] PETROL ENGINES
    9 13502592 12 04 648 ALTERNATOR, ASSY., 100 AMP (IDENT BM) (USED WITH MANUAL TRANSMISSION) 1
    9 13500330 12 04 649 ALTERNATOR, ASSY., 100 AMP (IDENT ACP) (USED WITH AUTOMATIC TRANSMISSION) 1
    8 13500331 12 04 650 ALTERNATOR, ASSY., 120 AMP (IDENT CD) (USED WITH MANUAL TRANSMISSION) 1
    8 13502591 12 04 647 ALTERNATOR, ASSY., 120 AMP (IDENT CB) (USED WITH AUTOMATIC TRANSMISSION) 1
    8 13500332 12 04 651 ALTERNATOR, ASSY., 140 AMP (IDENT CE) (USED WITH MANUAL TRANSMISSION) 1
    8 13502590 12 04 646 ALTERNATOR, ASSY., 140 AMP (IDENT CC) (USED WITH AUTOMATIC TRANSMISSION) 1
    10 12628024 12 04 917 BRACKET, MOUNTING, ALTERNATOR AND POWER STEERING PUMP
    11 11588735 12 04 930 SCREW, HEX.HD., M8 X 100, BRACKET TO ENGINE 3
    12 11588735 12 04 930 SCREW, HEX.HD., M8 X 100, ALTERNATOR TO BRACKET, POWER STEERING PUMP 2
    13 11588731 12 04 929 SCREW, HEX.HD., M8 X 65, BRACKET TO ENGINE 1
    14 11514596 9 12 881 NUT, HEX., M8, ALTERNATOR TO BRACKET 1
    15 11561936 20 05 674 STUD, ALTERNATOR, M8X16, M8X26.5 1
    16 55568445 12 04 223 PULLEY, ALTERNATOR (100 AMP) (MANUAL TRANSMISSION) 1
    DRIVE BELT - A20NHT[LDK],A20NFT[LHU] PETROL ENGINES
    17 12605492 18 54 297 PULLEY, IDLER, DRIVE BELT (IDENT AAB) 1
    18 12605208 13 42 417 BELT, DRIVE (IDENT WJT) 1
    19 12605175 13 40 584 BELT TENSIONER 1
    20 11516354 20 00 236 SCREW, HEX.HD., M10 X 60, TENSIONER TO CYLINDER BLOCK 1
  6. #1
    IGNITION MODULE - A28NET,A28NER PETROL ENGINES
    1 (12618542) (12 08 087) MODULE, IGNITION COIL (NLS.- USE 12632479) 1
    2 11588715 48 05 147 SCREW, M6 X 35, IGNITION COIL TO CYLINDER HEAD 6
    SPARK PLUG - A28NET,A28NER PETROL ENGINES
    3 55564748 12 14 065 PLUG, ASSY., SPARK (D1LFR7B1OG) 6
    STARTER - A28NET,A28NER PETROL ENGINES
    4 55563538 12 02 357 STARTER, ASSY. (C) A1076971- 1
    5 11588740 20 05 278 SCREW, HEX.HD., M10 X 40, STARTER TO CYLINDER BLOCK 2
    6 13277141 6 62 924 STUD, STARTER MOTOR TO CYLINDER BLOCK 1
    7 11900451 20 98 411 NUT, STARTER SOLENOID TERMINAL, M6 1
    ALTERNATOR - A28NET,A28NER PETROL ENGINES
    8 13502584 12 04 645 ALTERNATOR, ASSY., 150 AMP (IDENT CJ) 1
    9 55567913 12 04 195 -PULLEY, ALTERNATOR, 150 AMP 1
    10 11518634 12 04 947 SCREW, ALTERNATOR, M10 X 80 2
    DRIVE BELT - A28NET,A28NER PETROL ENGINES
    11 55567786 13 40 283 BELT, DRIVE (IDENT KH) 1
    12 12610680 13 40 270 PULLEY, IDLER, DRIVE BELT 1
  7. #1
    GLOW PLUG CONTROL UNIT - A20DTC[LCD],A20DTL[LBQ],A20DTJ[LBX],A20DT[LBR],A20DTH[LBS],A20DTR[LBY] DIESEL ENGINES
    1 55563423 12 32 331 GLOW PLUG CONTROL UNIT (C) -91 1
    1 55574293 12 37 783 GLOW PLUG CONTROL UNIT (C) 91- 1
    2 13243606 2 60 428 BRACKET, GLOW PLUG CONTROL UNIT (FOR USE WITH 75AMP BATTERY) (FOR USE WITH 85AMP BATTERY) (FOR USE WITH 95AMP BATTERY) 1
    GLOW PLUG - A20DTC[LCD],A20DTL[LBQ],A20DTJ[LBX],A20DT[LBR],A20DTH[LBS],A20DTR[LBY] DIESEL ENGINES
    3 55564162 12 14 334 PLUG, ASSY., GLOW, HEATER A20DTC[LCD], A20DTL[LBQ], A20DTJ[LBX], A20DT[LBR], A20DTH[LBS] 4
    4 (55564163) (18 26 354) PLUG, ASSY., GLOW, WITH CYLINDER PRESSURE SENSOR (NLS.- USE 55579436) 4
    STARTER - A20DTC[LCD],A20DTL[LBQ],A20DTJ[LBX],A20DT[LBR],A20DTH[LBS],A20DTR[LBY] DIESEL ENGINES
    5 55352882 62 02 073 STARTER, ASSY. (USED WITH MANUAL TRANSMISSION) (EXCEPT STOP/START ENGINE SYSTEM) A20DTC[LCD], A20DTL[LBQ], A20DTJ[LBX], A20DT[LBR], A20DTR[LBY] 1
    5 55352882 62 02 073 STARTER, ASSY. (USED WITH MANUAL TRANSMISSION) A20DTH[LBS] (C) -91999999 1
    5 55353857 62 02 074 STARTER, ASSY. (USED WITH MANUAL TRANSMISSION) A20DTH[LBS] (C) A1000001- B1999999 1
    5 55352882 62 02 073 STARTER, ASSY. (USED WITH MANUAL TRANSMISSION) (EXCEPT STOP/START ENGINE SYSTEM) A20DTH[LBS] (C) C1000001- 1
    5 55572065 12 02 216 STARTER, ASSY. (USED WITH MANUAL TRANSMISSION) (FOR STOP/START ENGINE SYSTEM) 1
    5 55353857 62 02 074 STARTER, ASSY. (USED WITH AUTOMATIC TRANSMISSION) (C) -B1999999 1
    5 55585237 12 02 282 STARTER, ASSY. (USED WITH AUTOMATIC TRANSMISSION) (C) C1000001- 1
    6 11588727 20 00 272 SCREW, M8 X 45, STARTER TO CYLINDER BLOCK 1
    7 55354470 12 02 665 STUD, M8 X 67, STARTER MOTOR TO CYLINDER BLOCK 1
    ALTERNATOR - A20DTC[LCD],A20DTL[LBQ],A20DTJ[LBX],A20DT[LBR],A20DTH[LBS],A20DTR[LBY] DIESEL ENGINES
    8 13502583 12 04 643 ALTERNATOR, ASSY., 100 AMP (IDENT BJ) 1
    9 13502582 12 04 642 ALTERNATOR, ASSY., 120 AMP (IDENT CF) 1
    9 13502581 12 04 623 ALTERNATOR, ASSY., 140 AMP (IDENT CG) 1
    10 55565443 12 04 291 -PULLEY, ALTERNATOR (FOR USE WITH 100 AMP. ALTERNATOR) 1
    10 13258483 12 04 177 -PULLEY, ALTERNATOR (FOR USE WITH 120/140 AMP. ALTERNATOR) 1
    11 55181226 12 04 568 SUPPORT, ALTERNATOR MOUNTING, UPPER 1
    12 11589280 6 84 743 SCREW, ALTERNATOR TO BRACKET, UPPER, M12 X 90 1
    13 11589272 12 04 931 SCREW, HEX.HD., M12 X 30, ALTERNATOR TO BRACKET, UPPER
    14 11589274 12 04 936 SCREW, ALTERNATOR TO BRACKET, M12 X 40, LOWER 1
    DRIVE BELT - A20DTC[LCD],A20DTL[LBQ],A20DTJ[LBX],A20DT[LBR],A20DTH[LBS],A20DTR[LBY] DIESEL ENGINES
    15 55562866 13 40 272 BELT, DRIVE (IDENT KF ALSO SERVICES IDENTS KE, KG) (PRODUCTION NO. 55563396) (C) -B1999999
    15 55578486 13 40 027 BELT, DRIVE (IDENT AACF) (C) C1000001-
    16 55562864 13 40 269 TENSIONER, DRIVE BELT (IDENT BC) 1
    17 55562865 18 54 740 PULLEY, IDLER, DRIVE BELT 1
    18 55569083 18 54 392 PULLEY, IDLER, DRIVE BELT (EXC.AIR CONDITIONING) A20DTH[LBS], A20DTJ[LBX], A20DT[LBR] 1
    19 97250750 56 36 412 -PULLEY, IDLER, DRIVE BELT, LESS SCREW (EXC.AIR CONDITIONING) A20DTJ[LBX], A20DTH[LBS] (C) -C1 1
    19 97250750 56 36 412 -PULLEY, IDLER, DRIVE BELT, LESS SCREW (FOR NON-VARIABLE RATIO POWER STEERING) A20DTL[LBQ], A20DT[LBR], A20DTH[LBS], A20DTR[LBY] (C) C1000001- C1 1
    19 55581830 6 36 257 -PULLEY, IDLER, DRIVE BELT, WITH SCREW (FOR NON-VARIABLE RATIO POWER STEERING) A20DTL[LBQ], A20DT[LBR], A20DTH[LBS], A20DTR[LBY] (C) C1- 1
    20 11588743 20 05 329 -SCREW, HEX.HD., M10 X 55, PULLEY (EXCEPT AIR CONDITIONING) A20DTJ[LBX], A20DTH[LBS] (C) -C1 1
    20 11588743 20 05 329 -SCREW, HEX.HD., M10 X 55, PULLEY (FOR NON-VARIABLE RATIO POWER STEERING) A20DTL[LBQ], A20DT[LBR], A20DTH[LBS], A20DTR[LBY] (C) C1000001- C1 1
    21 13101669 63 40 550 COVER, BEARING, IDLER PULLEY (FOR NON-VARIABLE RATIO POWER STEERING) A20DTL[LBQ], A20DT[LBR], A20DTH[LBS], A20DTR[LBY] (C) C1000001- 1
    22 11588724 3 74 836 SCREW, HEX.HD., M8 X 30, DRIVE BELT TENSIONER 2
    23 11588725 20 00 364 SCREW, HEX.HD., M8 X 35, BRACKET, PULLEY (EXCEPT AIR CONDITIONING) A20DTJ[LBX], A20DTH[LBS], A20DT[LBR] (C) -91999999 3
    23 11588726 20 00 152 SCREW, HEX.HD., M8 X 40, BRACKET, PULLEY (EXCEPT AIR CONDITIONING) A20DTJ[LBX], A20DTH[LBS] (C) A1000001- 3
    24 55570104 13 40 006 BRACKET, IDLER PULLEY (FOR NON-VARIABLE RATIO POWER STEERING) (C) C1000001- 1
  1. Insignia engine ECM
    By soulman in forum Insignia
    Last Post: 25th March 2016, 08:25 PM
  2. Cooling fan problem
    By Rob in forum Zafira
    Last Post: 18th July 2013, 07:21 PM
  3. Engine code
    By mull3tt mk5 in forum Astra
    Last Post: 6th December 2012, 11:00 AM
  4. Engine Diagram: What is it?
    By samnjl in forum Astra
    Last Post: 21st November 2012, 10:00 AM
  5. Engine and Cooling
    By pecky in forum P - ELECTRICAL
    Last Post: 6th December 2011, 08:07 PM
insignia alternator 13500331
cooler plugs a16xer
55563530 uk
