Results 1 to 10 of 16
    Member Ian T's Avatar
    Feb 2013
    Orpington, Kent
    72
    Astra H 1.7 diesel
    Retrofit CDC40, GID, DAB and UHP4 to AstraH
    Right, after a fair bit of reading up and looking at the wiring diagrams in TIS etc, I think I know how to do this, can I check my assumptions please?
    First, the GID needs to come from an Astra (so temp display will work) - I've got one coming that has the KP ident, think that is right.
    CDC40 can come from Vectra or Astra, got an Astra Blaupunkt one coming (ridge down the front) - shame it's silver as my dash is charcoal.
    DAB module is the same in all cars, needs antenna and base, antenna loom, shares same coding as radio.
    UHP4 is the same in all cars, shares coding with radio and needs mic and loom. I believe this can be reinitialised by Tech2, but presumably ONLY if it hasn't already got the latest firmware?
    Looms - it looks like the best method is to buy a Parrot type radio loom passthrough cable and modify that to add the other functions, the question is, do any of the accessories need anything other than soldering in parallel with the existing connections?
    I am working on the basis of trying to acquire the UHP4 ane DAB units with loom plugs and tails of cable, which should explain better what I mean above about simply matching the connections to the back of the headunit via an adaptor cable.
    Thanks for any advice,
    Ian.
    PS, if anyone has a good halogen headlamp (offside) with the black internals for sale after an AFL retrofit, do let me know.
      7,460
      Pretty much all spot on, except you can re-flash the UHP module with SPS and tech2 regardless of current firmware or not. It is how the voice language is changed so it lets you do it any time unlike other modules. It is the only way to decode a UHP module.
      If you have the connectors with a bit of cable attached then yes it is just extending and soldering to the correct places as per the wiring diagrams.
      You often find vectra DAB kits come with some/all of the loom on ebay.
      Feb 2013
      Orpington, Kent
      72
      Astra H 1.7 diesel
      Well, all of this has been in and working for a long time now and I really rate the setup. The CDC40 is an excellent upgrade and while the factory speakers are purported to have a lower resistance, the standard speakers in my 2004 1.7 Club model match it very well and produce a sound that even as a lapsed car HIFI nut, I am happy with.
      My next quest is to fit AUX in to this setup and it strikes me there are only a limited number of ways to do it, so thought I would post up here.
      CDC40 appears never to have had a DAB option while fitted with DAB, yet the DAB box seems to be needed in order to enable audio from the aux source (which it uses) to be routed to the amplifier. On the face of it, it seems the way to use the aux source in conjunction with DAB would be to break the audio wires in my loom extension behind the head unit and fit a double changeover relay with a switch remoted out to the ashtray area. That would leave the DAB box and Head Unit thinking they are working together but rout sound from the aux socket onto that pair of inputs.
      Are there any other ways of doing it, particularly that display "Aux in" or similar on the display rather than "BBC Radio 4" or similar?
      Cheers,
      Ian.
      7,460
      Using a changeover switch on the audio feed of the DAB is the only way I found to get AUX working. Don't need a relay, maplin used to sell a 4 pole change over switch for a few quid, just use 3 of the poles and mount the switch somewhere.
      Member Knolly42's Avatar
      Nov 2013
      Berkshire
      2
      Vectra cdti
      Hi, hope you can help by giving an opinion on something.
      I'd like to get the switch on my vehicle and found a suggestion that the earth can be switched?
      http://i52.photobucket.com/albums/g2...2/DABAUXIN.jpg
      Is it advisable/viable given the potential for the DAB to get another connection to earth and try to continue driving L/R audio? Or am I over-reacting?
      7,460
      No don't do it that way, it is much cleaner to use a changeover switch. This is what I use and is cheap enough http://www.maplin.co.uk/4pdt-toggle-switch-2343
      Nov 2013
      Berkshire
      2
      Vectra cdti
      Thanks!!
      Any special requirements on the audio socket cable? Someone suggested a 4 pin http://www.ebay.co.uk/itm/XA9951-Mus...item4abc4088bf
      Isn't that overkill or would any shielded L+R+GND do the trick?
      7,460
      Any shielded audio cable will work, no need to go overboard, its a car at the end of the day, not a music studio.
      Member Lao's Avatar
      Mar 2014
      Romania
      12
      Vectra C Estate
      If I live in an area where I don't have DAB broadcasting, can I just eliminate the ground wire coming from the DAB box to the CDC40? Or do I need it in place for the HU to sense it before I cut it via a switch?
      7,460
      Quote Originally Posted by Lao View Post
      No, if the DAB box doesn't get a signal, the CDC40 will not allow any audio in.
  1. Is it possible to connect aftermarket DAB+ adapter directly to CDC40 Opera?
    By perdaniel in forum Infotainment - ICE - In Car Entertainment
    Last Post: 23rd October 2019, 10:10 AM
  2. CDC40 and GID help with virgin
    By veteran in forum Decoding
    Last Post: 6th November 2018, 11:39 PM
  3. CDC40 and GID help with virgin
    By veteran in forum Infotainment - ICE - In Car Entertainment
    Last Post: 29th October 2018, 05:15 PM
  4. [FOR SALE] astra h cdc40 uhp4 bluetooth gid and loom
    By jpbroad1970 in forum Parts For Sale
    Last Post: 5th May 2016, 07:02 PM
https:www.diagnostics.org.ukshowthread.php1507-Retrofit-CDC40-GID-DAB-and-UHP4-to-AstraH
vauxhall dab 45 wiring
uhp4
cdc40 dab module
astra h hu connection diagramcdc40 opera gid retro fit vectra cUHP4 Vectra locationvauxhall cdc40 dabhow to install dab module vauxhall insigniafit dab to cdc40cdc40 dab auxvauxhall astra dab moduleadd dab to a cdc40retrofit dab vauxhall insigniainsignia retrofit dabuhp4 cdc40astra h dab wiring diagramuce uhp4reading flash in uhp4http:www.diagnostics.org.ukshopsearch-by-vehicleastra-hbluetooth-uhp4-kit.htmlcdc40 astra hastra h dab retrofitretro fit insignia dab aerialretrofit cdc40fitting cdc40
