Hi, I have a Vauxhall Combo D ,2014 Year, 1.6 (A16FDH) with a suspected Ecu Fault. I would be very grateful for any help or advice on the possibility of sourcing a used replacement Bosch ecu from breakers or auction site etc and programming it to the van using SPS on Service Box using the Vauxhall Legacy section. I have a Launch J box 2- J2534 Pass Thru device. I was wondering is it possible to programme a donor ecu on this van using SPS? what info is actually required, like pin code etc? and if so what would the recommended procedure be to follow when carrying out the ecu swap. After sending the ecu away for testing to ecutesting.com they were unable to Repair the unit so kindly returned to us free of charge hence why I was now considering the possibility of replacing the control module with a used one. Thanks in advance for any help
