Results 1 to 7 of 7
    Member Solenoid's Avatar
    Aug 2023
    The Netherlands
    3
    Vectra C
    UHP4 related questions
    From a scrap yard car, I got a complete ICE kit (CID, CD70 and UHP4) to retrofit in my Vectra C (2006). Unfortunately, I wasn't able to unmarry the components from the car.
    The CID and CD70 went without problem thanks to Pecky's decoder, however, the UHP4 is causing issues (UHP Safe).
    I tried resetting the components, activating theft protection using the UHP4 code and deactivating it again. That didn't work, as the latter just gave me 'programming failed' in the OPCOM. Curiously enough, despite 'Display SAFE and Headunit SAFE', the UHP SAFE warning disappeared and I could use the UHP4. Deprogramming the UHP4 did succeed in the activation (pairing) of the CID and EHU, inverting the result (UHP SAFE again). Unfortunately, I didn't yet find anyone who wants to help me out with a SPS upgrade...
    Further, there are some wirings that I don't quite understand. First, from the microphone: it has a white, black and brown wire. Since the black wire connects to the shielding of the cable I suspect ground, but I have no idea wether the black or brown wire is MIC+, neither where the other wire should connect to.
    There are also serial wires with no mentions online (CL KL30, Ser TX+, Ser TX- Ser RX +, Ser RX -, NF In+, NF In-, SNDREQ). I didn't see others connect them, which makes me curious where those are used for.
      1,367
      it should all unpair as one unit.. although if the car had ECC (electronic climate) you would need to disable this from all of the modules, CID, CD70, UHP4... SPS flashing will wipe the unit which seems to be your best option at this stage of the game.
      The other serial wires are only for the handset which had a base which attached to the armrest to replace the cupholders and isnt needed for the bluetooth functionality to work
      Member Arbe_GTC's Avatar
      Dec 2010
      Madrid, Spain
      23
      Astra H GTC 1.9CDTI & Astra K 1.6T
      Quote Originally Posted by soulman View Post
      Thats corrects. perform a SPS programming to the UHP, and this wipe the stored code in the UHP. then you can programm it normaly.
      Aug 2023
      The Netherlands
      3
      Vectra C
      I reflashed the UHP4 and programmed it using someone's Tech 2. It works (tested calling), but a 'Program UHP' message appears every few seconds. It's not blocking, like the UHP Safe message.
      What have I missed?
      1,367
      That is UHP not fully programmed, go back to the beginning and program again with tech2
      Dec 2010
      Madrid, Spain
      23
      you need program the code index
      for Astra h: https://tech2.guru/astra-h-code-index-uhp4-bluetooth-2/
      You can check your code in Tis2web, globaltis, tis2000...
      and program the code using tech2
      Member WolffNum's Avatar
      Jan 2024
      Prestonsburg KY
      1
      ElonNumIJ
      Have you encountered any challenges or issues in programming the UHP4, and do you have insights into the recurring 'Program UHP' message despite successful programming?
  1. Replies: 14
    Last Post: 5th September 2016, 11:03 PM
  2. A few questions for you lot
    By benboym3 in forum Vectra
    Last Post: 29th March 2013, 04:10 PM
  3. Bluetooth UHP4 - programming questions
    By arshad in forum Bluetooth UHP4
    Last Post: 9th February 2012, 01:04 PM
